| Message |
This engine was pulled from my car in 2004 when #6 injector replacement (o-ring rolled) caused fuel to leak in cylinder causing hydro-lock in #6 immediately after starting engine. (idling about 600rpm for 2 seconds) This stopped the motor and bent the #6 rod so out came the motor, I disasemble engine and placed the parts in crates, drenched the block in WD-40 and wrap with trash bag and it been in the garage ever since. I purcheased a fresh Stillen long-block and hyad it installed since I needed the car right away (DD). The engine had 39K ORIGINAL MILES. $1600.00 Pictures: [ http://www.facebook.com/media/set/?set=a.1700286485431.69908.1786018714&l=60d9c09ae7 ] History: This car was purchased new in 1990 by my father and barely driven over the years except weekends. Toward the end of his ownership the car would go over 2 months between drives. (baby drives at that - he was in his early 70s). I bought the virtually brand new car from my father in 2003 with 28,000 miles!!!! Engine was marinated in in Mobil 1 from day one. I ran it until the injector died. The bent rod never touch the block or hurt anything. You could clean this engine it up, replace the rod and put it back together and run it 70,000 miles if you wanted to. I would spec out the crankshaft just to be sure. IMO You don't find a fresh motor like this very often anymore!
